the blade is affixed to a large flat piece of cherry branch stuck over a wide dowel. the method to affix it is just a large washer and a lag bolt.
These irons are dandy for this stuff, they're hard and pretty tough and about $10 on alibaba. You could refinish 5 houses with a single one of them.
Be nice to get some HSS for the flat work, best stuff I have is likely a plane iron
honed @90 up the sides which I use for heavy work.
A divil for the unaware as it will gouge the underside of the cap fairly lively,
so I try and not work to the business end of that beater plane.
Made two blank profiles yesterday, the blu tack transfer was out by a country mile, lol!
But at least it gave a rough estimate on where to grind and file.
Next time I will use some masking tape so I can get the most important part done easier.
The vertical lines if you will is the most important, where the lines drawn on the masking tape would come into play,
then it's just a matter of getting the flats right, and finally the curves to fully seat the tool into the work,
Find a gap, flats and curves again.
It took me an age to make the first one, as I was learning a few things.
A really interesting study to honestly shape various profiles,
rather than think of things being like radii of differing diameters, this teaches one the hard lessons about profiles for one isn't used to making anything but roundovers.
I suppose this kinda thing is bet into someone studying in architecture, and that long round (in between the o's on "doors") was the most interesting to me,
A conflict of sorts for one not used to anything but a radius.
No abnormalities on the doors, although the tool needs skewing on some,
as you can move about panels in doors quite substantially, which I forgot to mention earlier whilst I was trying to get those tenons to seat home.
Time to make the tool now, and even with a perfectly shaped master,
the tool was still out by a lot.
I suppose the master is the profile, and then another tool made to copy this but
should be smaller by whatever percentage, so one can quickly make another tool in a few mins, as it took a half hour to make the second from scratch,
and still required the work to be done in hand at the scribe and profile, rather than in the vise.
The needle file assortment's, knife file and the half round was mostly used for the entire job.
Went heavy handed with the grinder and can report the marker ink lasts and doesn't require re-doing.
Done the guts of an hours work scraping today,
This would certainly be difficult to do by another method,
unless one has access to the real nitromorris in large quantities.
Cannot really show the tool working with one hand,
Only learning yet, seems possibly best procedure is to do the long grain first,
as not to wipe out the edge on the end grain with splits and whatnot.
Seems pretty inconspicuous ATM, maybe that will change when the end grain gets somewhat visible.
Going to see how the tool lasts and do a rough job of all the long edges like below,
and then end grain.
Should the tool require a touch up, then I can revisit some areas where the tool wasn't as keen to remove the old varnish afterwards.
Not too worried about the flats as a chisel could do that easily.
Not going to be fun using the tool with these upper panels, might need something better than a chair.
Tom
