Hi all,
thanks for the replies and votes....
Had a look at the commutator - looks fine through the brush-holes. But then I noticed some screws on the end-cap. Oh-oh. Takes off end cap and three bits fall out. Two plastic and one magnetic. And a screw. Ok four bits fell out. The screw was a pz2 but its recess was filled with plastic. The inside of the end cap was worn immediately over the end of the motor shaft. So the screw was loose, and rubbed the inside of the case until it filled the slots with plastic. There was not enough clearance for the part to become completely dislodged but enough for them to be out of position a little.
I have sort-of figured out how the bits should fit together, and they leave the magnetic bit near to some electrickery with wires headed off into the motor housing. Could this be the the mechanism that detects when or how fast the motor is turning (spinning magnet on the shaft, coil of wire in the electrickery?) Could the magnet being loose be responsible for the motors misbehaviour? or is it caused by the misbehaviour?
The tool has a 'soft start' mechanism - I have no idea how that works, or even if this is relevant.
I will try the motor out, but first I need to find a way to tighten the pz2 screw in the end of the shaft. - maybe some threadlock?
Anyone out there know anything about these motors?
Oh, and those five votes for a different machine - what would you recommend?
This machine, although it cost about 150gbp new easily saved me that (and more) employing an expert to patch-match my wood-block floor, and has done several jobs since then (including lots of rubbish/firewood chopping and the odd nail or screw) so I am not too disappointed. If I can resurrect it that would please my wallet though.
