Ttrees
Iroko loco!
Hello folks, wondering if you can help me with this one..
This basic wee radio has seen me through quite a few metalworking projects, and is now just emitting a buzz when plugged in...
I haven't used it in a good while, actually doing some woodworking if you can believe it :shock:
and presumed the problem was just a damaged cable, which I realised today is not the problem.
After taking it apart and giving it an inspection/clean I am left presuming that the problem is in the input, (not pictured)
as it sounds like an arc is happening when plugged in, happening in all modes...empty tape deck, CD, FM/AM.
Another clue was I was finding the channels were so hard to tune in to...like a drop of a feather to fine tune it,
and on some channels it was picking up two at a time...giving some funky remixes (hammer)
Now the radio doesn't work, and I doubt the other unused settings work either.
I took it apart expecting the speakers to be caked in metal dust, and cleaned the small amount off with a magnetic screwdriver,
I could only get at the back of the speakers at the actual magnet though...
Anyway assembled it again and the problem still the exact same.
This leaves me to presume it is at the input where it looks to be a transformer or something... a wrapping around a box shape.
I am not a bright spark in this field whatsoever, and have no knowledge of this sort of thing.
I dared not to touch anything that looked dangerous, as I learned my lesson when disassembling a disposable camera
when I was little....dang thing stuck to me and wouldn't come off my finger when vigorously shaken =D>
It would probably make a useful device, now come to think of it
Whats the advice from this point ?
Do I have to drain the power or wait till the charge dissipates?
Is it the dangerous bit atall, or if that's elsewhere?
Am I on the right track even?
The only other place to check in more detail I suppose, would be the tuning and volume entry points.
Here is a useless piccy which was just intended for reassembly, so I suppose I might have to go through this again
It may help you save me from another sticky situation :lol:
Tom
Tom
