Hi Guys,
I am instructed by the wife to make a radiator cover/cabinet.
I am to use 3/4" american oak and the outer dimensions of the cover are 1600 x 620 x 190.
I think the water in the radiator is approx 60 degrees.
Obviously the wood is going to dry some under these conditions when the radiator is used in the winter and the wood will probably increase its moisture in the summer when the radiator is not in use.
Can anyone recommend a finish that will fix the moisture content?
If thats not possible should I consider allowing the wood to move by means of some unfixed joints?
Cheers in advance
Garry
[/img]
Cheers in advance
Garry
[/img]
