dedee
Roy,
Oh dear. Why will it not work?
To answer your questions.
The current water heater is made by Thermor and is heated electrically. It is made from steel. The heating element is a "stealite resistor housed in an enameled sheath". The tank has an enameled lining and the heat insulation is polyurethane foam. The insulation is very good. Even when at max temperature the outside of the tank does not even feel warm.
It is a 250l tank. and looks like this
I have written to Thermor about feeding heated water rather than cold into their appliance and am awaiting a reply.
The overnight venting (when it is heating the water) is perfectly normal. This type of water heater is very common here.
Thanks for your help, sorry if I am being a bit dim.
Andy
![familio-thermor-chauffe-eau-electri.jpg](https://proxy.imagearchive.com/1d4/1d435a839acf89ada23e808d2cb6ba66.jpg)
Andy
