RogerP
Frankly, in use, I can't tell a much of difference they're both very powerful.DennisCA":94d8dk88 said:I wonder why the americans get a massive 2400W and only 2000W here?
Will do thanks. Also good to know you're happy with it out of the table.Ed Bray":2quawz6z said:It would be worth a search on Routerforums.com using Triton TRA001 for a good review of the router and its use both in and out of the table.
Had I not other routers that I use out of the table I would not hesitate to use the TRA001 if I needed to.
That did cross my mind, as there's a lot of liberties taken with ratings of motors - especially the trick of claiming a horsepower figure on US tools that's not actually possible with the wattage you could (constantly) draw from a standard 110v socket (basically using the "breaking" current, IRC).paulrockliffe":2quawz6z said:I thought the power difference int he marketing was because in some countries it's the input power that's quoted, in others it's the output power.
Thanks - that makes a lot of sense (in the "T11 is a DW625 with an above table fine height adjuster" argument).mseries":2quawz6z said:The Dewalt 625 is the same as the Trend T10.
The Trend T11 is the same as the above except for the base which is optimised for undertable use by providing above table height adjustment.
Nice looking setup. What did you use for the laminating (formica)?gidon":2dg09tmf said:I use a Trend T11 - which is designed for router table use. I use an Xtreme Xtension collet extender and attach the router directly to the table. Much easier plus the quick change feature on the XX makes using the table a breeze.
Here's my table: two sheets of MDF, laminated with a Trend T11 attached directly to top. I picked up the Incra fence in the US for £50! (It was quite some time ago when the exchange rate was fantastic!)
Yes, and it works fine. I've got a CNC machine with a Porter Cable 892 router fitted, where I rewired the cable for a yellow 110v building site type plug, and use a transformer.mseries":2dg09tmf said:I just re-read the original post, can you not use a US tool with a 110V transformer ?
sploo":32l45rtc said:Nice looking setup. What did you use for the laminating (formica)?gidon":32l45rtc said:I use a Trend T11 - which is designed for router table use. I use an Xtreme Xtension collet extender and attach the router directly to the table. Much easier plus the quick change feature on the XX makes using the table a breeze.
Thanks. I was just wondering if it was any special/specific material that you used.gidon":3txgqeil said:Thanks. I think I got the laminate from Jewsons - but it was a long time ago.
phil.p":508q5vph said:This is the second post I've read since yesterday that's said our voltage is 220v - I thought our mains were 230v?
sploo":18fmzkv9 said:phil.p":18fmzkv9 said:This is the second post I've read since yesterday that's said our voltage is 220v - I thought our mains were 230v?
It varies (there's an allowable margin of error). At my place it's usually 230+ but I just noticed 9.1 x 220 ~= 2000.
For many years, mainland Western Europe has used a mains electricity supply rated at nominally 220VAC 50Hz. The UK used 240VAC 50Hz.
Currently, ALL Western European supplies are classified 230VAC. In reality there is no 230VAC supply unless you create one locally. 230VAC was a “standard” created during European "harmonisation" to give a single voltage standard across Western Europe, including UK and Irish Republic.
Although the ideal would have been to have a single voltage there were too many political, financial and technical obstacles to reduce UK voltage to European levels or to increase European voltage to UK levels, so a new standard was created to cover both. This was achieved by changing the tolerances of previously existing supply standards. UK voltage to 240VAC + 6% and - 10% and European to 220VAC +10% and -6% (thereby creating a manageable overlap) and we would call these two combined 230VAC, despite the fact that nobody was intentionally generating at 230VAC!
It depends on what you need, Dennis. Like most tradesmen the vast majority of my work is done out of the table, hand held. Where things need to be done in the table (e.g. heavy profiling or large rebates) then a spindle moulder or overhead pin router is the way to go if the budget permits. I suspect that far more heavy-duty 1/2in routers are sold to tradesmen and workshops than to hobbyists.DennisCA":lbs16ava said:European routers seem to be quite lacking in proper design IMO. I want the US style cylindrical bodied ones that you can swap out bases for, or use the router in the table with only the cylindrical body.
I suspect it has something to do with the way that measurements are taken. In the USA manufacturers are allowed to quote HP figures based on maximum current drawn or some such which allows them to quote outlandishly high power outputs. But a 2000watt router will still have a lot more power and torque than a 1400 watt one - something you soon realise when you start working solid surface (e.g. Corian) which hammers equipment mercilesslyDennisCA":lbs16ava said:I wonder why the americans get a massive 2400W and only 2000W here?
But to be honest it seems alot of the high quality counterparts are rated at 1400 and 1600 watts so perhaps it's not all about the wattage.
From what I've seen so far, the TRA001 looks to have been very well thought out - a bit large and heavy for handheld use perhaps, but very suited for table use (which is often a weak point of plunge routers).Job and Knock":1uz6jj05 said:It depends on what you need, Dennis. Like most tradesmen the vast majority of my work is done out of the table, hand held. Where things need to be done in the table (e.g. heavy profiling or large rebates) then a spindle moulder or overhead pin router is the way to go if the budget permits. I suspect that far more heavy-duty 1/2in routers are sold to tradesmen and workshops than to hobbyists.
Yep. It always amuses me when you see a tool sold in the US that claims a horsepower figure that wouldn't actually be possible based on the necessary current draw from a standard wall outlet (i.e. it's a "marketing" derived figure rather than one derived from any sort of real world use).Job and Knock":1uz6jj05 said:I suspect it has something to do with the way that measurements are taken. In the USA manufacturers are allowed to quote HP figures based on maximum current drawn or some such which allows them to quote outlandishly high power outputs. But a 2000watt router will still have a lot more power and torque than a 1400 watt one - something you soon realise when you start working solid surface (e.g. Corian) which hammers equipment mercilessly
Job and Knock":2yrl8hdq said:It depends on what you need, Dennis. Like most tradesmen the vast majority of my work is done out of the table, hand held. Where things need to be done in the table (e.g. heavy profiling or large rebates) then a spindle moulder or overhead pin router is the way to go if the budget permits. I suspect that far more heavy-duty 1/2in routers are sold to tradesmen and workshops than to hobbyists.
