not exciting or sexy in the least, very simple built in units with LED lights in the face frame, Oak veneered MDF tops. There is also a CD rack but I forgot to take any pictures of that.
I will add that we bought a Draco airless sprayer for this, and future projects, and I was very happy with the finish is gave.
Definitely not my usual thing, this memory box was requested by my wife for her eldest sisters 60th.
Its made from off cuts of American white oak apart from the CNC engraved panel which is a horrendously gnarly piece of European oak that must have gone through the sander at least a dozen times, thanks to @JonnyD for the cnc’ing.
You know what, that has given me an idea for an xmas present for my sister in law!
Looks great, which sprayer did you buy? Was it your first time spraying and how was the learning curve? Thinking about the spraying route for some windows I am making.
Lovely mitres on the corners of the linings, I can never get mine quite that accurate!
Nicely done and attractive! Amazing copper relief, your work also?
Your sitting room is inviting.
Thank you. No the copper is the one thing I can't lay claim to. We bought it at auction half way through the project and redesigned the top to accomodate it.
Bench for a slight upgrade of lathe. And to make it the right height for me. Jobs always take longer than you think. All timber I’ve been keeping because “that will get used for something”.
Good bits of damaged construction timber.
Legs Douglas Fir left over from a pergola.
Splay 5 degrees sideways and fore and aft. Front rail a bit of Oak that came from a recycle yard, Rubberwood shelves from discarded furniture and scrap metal collection for added weight!
Arghh! Disaster! The base packers meant the bolts were too short, so had to part with a fiver for a length of threaded bar and some nuts. Had all the coach bolts in stock.
Well it works, but clearly needs doors! Has taken 8 days.
Great bench. I've sailed in smaller, (and far worse built) ships than that!!
The Draco Magnum Truecoat 360.
Very easy to use even though the cable is stupidly short, It's not even half a meter and has a UK plug adapter (Draco are a USA company)
We didn't even need to water down the acrylic paint.
No sanding between coats either but you probably will need to if painting real wood.
A dovetail marker; I'm not sure if it made a difference but box number four was certainly an improvement. It *might* just be learning curve...
And because I suffer with the affliction *I-cannot-throw-away-even-the-smallest-pieces-of-wood-itis*,
A small box for the workshop made from the off cuts from the box made from construction waste. I like to think of it as reclaimed-reclaimed timber. Or reclaimed squared.
It's all good practice!
I made a folding stool for a friend - they wanted something to reach tall cabinets in the kitchen, but they didn't want it to be on display all the time.
I didn't have a table saw or a planer / thicknesser at the time, so I milled all the parts for it by hand from this slab of oak:
Scrub plane, followed with a jack plane produced square-ish edges:
To speed things up, I used a circular saw, taking passes on both sides, flipping the slab around, slowly increasing cut depth. Once the cut depth was maxed out, I cleared out the middle with a hand saw. The boards were not nearly the same thickness, which caused some headaches with positioning the seat boards later, if I was doing it again, I'd make sure the parts are definitely the same.
After a bit more sawing and drilling, I ended up with the parts ready for assembly:
Two middle seat boards had some pretty dramatic grain, unfortunately it doesn't pop as much after applying varnish :(
This contraption helped me get the correct final widths for the seat boards:
I glued everything up, and then took it all apart to apply some varnish:
And this is the finished product:
It's not perfect, I definitely wouldn't chamfer seat boards on both sides again, difficult to get rid of squeezout after the glue up.
I'd make sure all parts are identical, and I'd probably make myself some alignment jig for the glue up, it was awkward :D
The 'client' loves it though, so that's all that matters :D
