Post a photo of the last thing you made
Keepsake box made from ABW and Red Cedar. The inlay is Snakewood and the lining Sycamore. SmartButt hinges used with avoids the ugliness of a square knuckle.
This was my HVLP set up when I first got an Oneida super dust deputy.
I rigged it up to my extractor like this as I figured it would be for the quickest & that it would be handy to keep it mobile on the existing wheeled base.
In the nearly 3 years since I did this Iā€™ve not move it once šŸ¤¦ā€ā™‚ļø so clearly mobility wasnā€™t a necessity, also as expected I experienced quite a reduction in suction not only because of adding the cyclone (which I was expecting) but also the extra pipe & bends I used to keep it fitted to the original base.
My intention with re-jigging things was to reduce the pipework & by doing so increase the suction from its current 57% efficiency when measured against the impeller on its own.
First off I wanted to get as long & straight a piece of 5ā€ spiral duct as I could to the cyclone as this is beneficial for the cyclone to work effectively, although I had to incorporate a 45 degree bend on the inlet that is followed by a 2.8m piece of ducting that runs to roughly the centre point of the long workshop wall. From there the duct drops to the floor & a piece of flexible pipe is attached to it long enough to reach all of my machines, in doing this Iā€™ve halved the amount of 5ā€ flexible ducting I had on the system.
A piece of 3/4ā€ ply was fixed to the wall & floor then braced at the top onto which the impeller unit was bolted.
I built a simple unit for the fine filter to sit on the added bonus being it gave me some much needed storage space for a couple of systainers.
The streamlining of the system has taken it up to 72% efficiency a gain of 15% which I really pleased with as a fine filter & cyclone are always going to take a toll.
But the real proof as they say is in the pudding & on Thursday it got it first real workout & performed admirably
Having fixed up the router table and resigned myself that a spindle moulder will be in my future Iā€™ve been cracking on with the sash window.
Worked out the parting bead slot and the spiral balance slots and covers.
Iā€™m going to finish the slots above the sill to attempt to avoid/minimise water ingress points.
I was not confident with the saw down the side and bash out the pocket method, so I resorted to routing out the pockets and making covers for them.
Pulley recesses were also done with a router and template. The cordless palm router is my best friend.
Then I machined up all the staff and parting beads and the sill and head linings, as well as a couple of boards for secret Santa!
Sorry could get images in with the text, no idea why but theyā€™re all petty obvious!
Fitz
Fitz
Fitz , what are the shiny brass thingys were the windows run ? I think I know the answer but not sure.
They are pulleys that the sash cord runs over, the window sashes are counterweighted so that they are balanced. The image below (credit Ventrolla) shows how the overall window works.
Another box (same Japanese cedar construction waste stock); practice makes a slightly better box than the previous. Sometimes.
This time joined two pieces to make the base for a wider box (three pieces for the lid as I cut the sides short by two millimetres), reduced thickness to eight millimetres from ten and figured out that a sharper pencil helps to make better cuts for joints!
Another forty two metres of stock left...
I would like to do another round of chisel/plane sharpening now but minus two degrees C (about twenty eight degrees in old money) is quite prickly on the hands for water stones...
Spent the day making my 2nd set of coasters. Definitely better than my 1st set. And a wine gift box for a Christmas pressies. Made form yellow ceder. Smells great. Just not sure how to finish it. Or just leave it as it is.
    7.4 MB
    4.9 MB
    5.7 MB
