Cabinetman
That’s very nicely done, particularly like the cut out bit for the handle which also stops it racking I suppose. Is it Cherry?Portfolio case for a photographer.
Ian
I assume it's mains not solar.Little canopy for an outside light made with offcuts from a recently erected fence, it's coated with Barrettine wood preserver as a test piece to see how durable it is
Don’t you just hate it when you get those little cuts from big tiles? Drives me nuts.I’ve been back at my lads of late the builders left an awkward gap at the end of the bath 380mm wide, as with most modern houses storage is in short supply so it was decided on a full height cabinet to maximise this space.
After cutting panels to size & edge banding I figured it would be as easy to assemble the cabinet on site so I set up a couple of trestles in their kitchen & did the dominoing & drilling in there.
All the parts were then taken up into the bathroom & screwed together with confirmat screws,I figured this would be the easiest way to assemble the cabinet in such a confined space especially as it had to be built upright.
As the side of the unit faced into the bath & even though it the opposite end to the shower I thought it best to tile it, first lining it with Hardiebacker board.
Grouted & sealed
With push to open catches.
I’ve got to ask the obvious question. Why does an outside light need a canopy? Or is for aesthetics.Little canopy for an outside light made with offcuts from a recently erected fence, it's coated with Barrettine wood preserver as a test piece to see how durable it is
Precaution against water ingress, plus the aesthetics, and as mentioned it's just a test piece to determine durability. I'm curious about how well the fencing offcuts weather, curl, twist etc. The roof and back board are 3 pieces dowelled and glued, sides are two pieces.I’ve got to ask the obvious question. Why does an outside light need a canopy? Or is for aesthetics.
I made one for my new solar-powered light only to find out after fitting it doesn't work.Little canopy for an outside light made with offcuts from a recently erected fence, it's coated with Barrettine wood preserver as a test piece to see how durable it is
