Jameshow
Used by the police round here so should be reliable!Citroen Dispatch or Peugeot Expert or Toyota Proace ☺
I don't use camp sitesMake sure you book in advance, went a few years ago and most places were booked
They are fantastic.My partner has a significant birthday coming up so I thought I'd have a go at some wooden roses based on ideas from several YouTube channels. They needed a couple of bud vases as well.
The vases are turned from a piece of wood I've had sitting around for many years (probably elm) and are fitted with test tube inserts - in case she prefers real roses that need watering
The roses have stems cut from 12mm square lengths of Sapele and Walnut using a scroll saw and then sanded roundish. The whiter petals are shavings from a piece of construction softwood with the more orange petals made from pitch pine? shavings.
I threw a small piece of my recently acquired cherry tree the lathe to see what it wanted to be
I forgot to take a pic of the piece on the lathe before turning but I've circled the piece in the picture, the piece was only joined by a tiny bit of wood so it broke in two, the other half is going on the lathe next.Thats cooldid you get lots of bits breaking away or did it start with those edges? I dont suppose you got a photo of the blank?
Now that I have a 4jaw chuck I threw a small piece of my recently acquired cherry tree the lathe to see what it wanted to be, im actually really pleased, so far it has been sanded up to 800 (I know many will say that's a waste of time and sandpaper but I don't have abrasive pastes so I have to use what I have) once I get some beeswax on it I'll turn it around, remove the tenon and put my logo on it. This one will be a gift to the guy that gave me the cherry wood.
Have you got links to the YouTube videos?My partner has a significant birthday coming up so I thought I'd have a go at some wooden roses based on ideas from several YouTube channels. They needed a couple of bud vases as well.
Thanks Phil, it's all I have at the minute and having spent so much recently on the bench grinder, chuck and abranet abrasive mesh I'm flat broke for the foreseeable, sanding sealers, abrasive pastes and finishes are all that's on my Xmas list this year though so who knows.Pretty.. You'd do well to put a harder finish on it, though, beeswax alone will mark easily.
I've spent the last 3 years watching YouTube, I've only recently been able to make space in my garage and be able to afford to buy the peripherals to go with the lathe, I'd spend all day out there now if I could but the dogs need attention too so a couple hours a day is as much as I can justify out there for now. Having nice wood helps tooYour really getting into it!
Cheers James
You have inspired me tonight!I've spent the last 3 years watching YouTube, I've only recently been able to make space in my garage and be able to afford to buy the peripherals to go with the lathe, I'd spend all day out there now if I could but the dogs need attention too so a couple hours a day is as much as I can justify out there for now. Having nice wood helps too![]()
A very nice little bowl. Great colours.Thanks Phil, it's all I have at the minute and having spent so much recently on the bench grinder, chuck and abranet abrasive mesh I'm flat broke for the foreseeable, sanding sealers, abrasive pastes and finishes are all that's on my Xmas list this year though so who knows.
This morning I worked turned off the tenon and applied 2 thin coats of the beeswax into the wood and then realised I'd forgotten to print my logo on the base, oh well. I applied the wax with kitchen towel and with the lathe running on its lowest gear so about 450rpm and it has buffed out to a very nice sheen I'm totally in love with the red colouration and with the contrast between sapwood and grain wood, ive also impressed myself at getting the walls and base to a pretty even 5mm all the way through.
View attachment 121838View attachment 121839
