monkeybiter
I read somewhere, long ago, that they have made their way up to attics!phil.p":15h7ch68 said:I assume you're going to make a ladder for it so he can get up and down?![]()
Maybe bungalows in hillsides.
yetloh":1gvz69oi said:I'll do that then. I understand that hedgehogs are surprisingly good climbers, not much to fear if thay fall because their spines act as shock absorbers.
Jim
Nelsun":26flsgeg said:Very clever Naz. I bet it'd be real easy to c*ck it up and get the castors too high or too low.
Bm101":162hp3v3 said:Clever man. That is very tidy. Consider stolen.
You make it sound so easy. I'm sure I could find a way to put the wheels on the top...NazNomad":2j7wrpcf said:Nelsun":2j7wrpcf said:Very clever Naz. I bet it'd be real easy to c*ck it up and get the castors too high or too low.
It would, but I made the two levers first, complete with hinges & castors. then clamped them together in the 'working' position.
Set the table up on two bits of ¾ wood and then marked the holes for screwing the hinges on. That kinda meant the with the levers locked down, the table would be ¾'' off the floor.
It couldn't not be the right height, it just took a bit of sussing out beforehand. :-D
The perfect solution, however, is a space big enough so you don't need to wheel everything out on the driveway to use it. But if you have to, then don't struggle.
Can you not create a wooden ramp that sits over the steps when you need to cart stuff up & down?
marcros":tgsbxaqp said:I need to get a little light tent to photograph these I think.
