" Fitting windows; the horrible reality; " I can handle thatChip shop":9smsnkgk said:A lighter frame could be a consideration as I'll be on my scaffold tower contriving to pull the frame up on a rope. I was having a ponder about this manoeuvre the other night, how I'm going to go about doing it. When I was on the tower, bodge fixing one of the cills and putting masonary paint on. How the tower had to be positioned, was a gap between wall and tower, occurred to me just increase the gap and pulling the frame should be straightforward. My best mate is a roofer, tiler and plasterer and quite a bright spark, will ask if he has any additional ideas on getting frame up and into position
Err, soz if there's something I've missed here, but why would you be roping the frames up on a scaff tower? Surely they'll all be fitted from the inside...won't they?
Also, I think you might be in danger of over thinking the job. Your windows are pretty straightforward, other than the sliding sash...which, I imagine, will take a bit of making good on the inside.
" What will need to be done at some point is to measure from brick to brick on the outside " Do you mean measuring diagonal to diagonal to size the window opening? " then plaster to plaster on the inside " Not sure what you mean?ColeyS1":zf6k9r6q said:It looks like the sliding sash ones are in behind the first brick but the others further forward. What will need to be done at some point is to measure from brick to brick on the outside then plaster to plaster on the inside. I'm trying to take it at a steady pace at the moment. This will be quite important when you come to deciding frame dimensions. There may be a reason the frames where the sliding sash are at the moment, would be better off being buried in behind the brick. This might mean you'd need a chunky frame so for instance 12mm of it will be lost/buried behind the brick. It may be easier to just fit the others from the outside with narrow 57mm frames. The 69mm chunky frame you've buried 12mm would then match. A lot of it depends what lurks on the inside to which approach would be better. Let's keep the momentum going !
My main goal was to demonstrate why you didn't need the large rebate block but I feel progress has come on leaps and bounds since that discussion.
Would a 94mm deep frame look like it could work ? Is there any way you can measure how thick the frames are now? The sliding sash will no doubt be much thicker than your other windows.
Top right corner face of frame is 6cm from edge of brick work, top left is 5cm, bottom left and right both 4cm.ColeyS1":1qrussqu said:On the windows that haven't got brick or tiled cills, what's the biggest measurement you've got from the front/face of the brickwork to the face of the window frame ?
If they're all around the same size you go just work to the biggest.
Cheers, mores the merrier.Chip shop":q6fkfob6 said:Outer face of brick to the front face of each window I imagine (sorry Coley, if I'm treading on your toes)
" Then make different sized subcills for the ones that need it " So this is the plant on cill, that RobinBHM referred too?ColeyS1":u7w1snhf said:Oh I see, I thought you mentioned putting back like for like. Is the plastic double glazing being replaced with wood then ?
For simplicity it would probably be easier to make them all flush
Then make different sized subcills for the ones that need it. The sliding sash ones you have at the moment are obviously waterproof with no projection at the moment. If every other window besides these have projection, you could do those to match ?
I have a 3.75hp Axminster trade series WS1000TA spindle moulder and a monster of a 1hp roller feed also a new 125 x 60 x 30 rebate block, various other cutter blocks.I also have the Aquamac weather seal cutter.Chip shop":254my5wk said:Yup, that's a plant on cill alright!
If I was you, I'd get some timber and have a crack at making one. The biggest challange is the deep rebates, but with a little imagination you could do them with a table saw, router or one of them planes that old people use...if you don't have a spindle moulder.
Oh, and take your measurments from the inside(perhaps with a little bit of plaster chipped off) not the outside.
I'm still trying to get new planer to cut square as, I mentioned until I have square timber I'm reluctant to try and practice rebate cutting on the spindle.ColeyS1":1kp26f9b said:You'll be the one who's making them though ! How are you finding using the spindle moulder now ?
pollys13":1kt4zvb6 said:I have a 3.75hp Axminster trade series WS1000TA spindle moulder and a monster of a 1hp roller feed also a new 125 x 60 x 30 rebate block, various other cutter blocks.I also have the Aquamac weather seal cutter.Chip shop":1kt4zvb6 said:Yup, that's a plant on cill alright!
Attended Peter Seftons training day on the safe use of spindle moulder, ring fence, bearing guides etc. Familiar with the use and safe use of the machine. Also have a Axminster trade series 3 knife block, planer/ thicknesser, Axminster trade table saw with 2nd hand sliding table, 3.75hp 100mm depth of cut.
3hp bandsaw 10 inch cut, cabinet mortiser, hand planes which I'm in process of learning how to use. Joinery bench a work in progress. About to get some Redwood to practice on once I've sorted out surface planer to machine square.
pollys13":29ototit said:For reasons of economy, what I propose doing is working to a smaller scale, by that I mean not fully finished frame size 96mm x 69mm I think was what Coley mentioned, though still large enough to practice the jointing. I'm thinking of making up several practice windows say 36cm wide x 60cm high. I would need to perhaps get 100mm x 100mm PAR Redwood from Travis Perkins and rip down to working sections, or better to get other stock sizes of Redwood and not have to rip down? Design as in attached,part that is outlined in red, did this some while back to give me an idea roughly what size the glazing and the cost of one window style I'm intending to make.
