Hi you knowledgeable people I’m after a supplier for replacement reeves drive pulley’s for a sealey m900 / generic Chinese made lathe . Thanks guys ?
You can become a Supporting Member or just click here to donate.
Thank you Paul I’ll give them a callContact Axminster customer service, I think they stock spares for their version and I think they are all pretty much the same but with different livery depending who you bought it from.
Thanks for your reply Graham I willHi Mick, I have a friend who works in a place that specialises in manufacturing transmission systems. They sell belts and other such parts as part of the business. If you can find the type of belt, size and everything I can have a word and see if they stock it. Sadly I don't even get mates rates so it would be full price. If Axi falls through send me a message and I'll get back to you.
Thanks PeteA search pulled up this AWGB Woodturning Forum thread. An extra source or two above the ones already mentioned.
It sounds as if you need the notoriously brittle drive cones. If so, I hope @Paul Hannaby's suggestion helps.
If it is just the belt, there are loads of online places. I got one for about 1/3 of the price for an axminster one when I had to change mine.
Otherwise , I guess it is eBay / marketplace for a dead lathe to take parts off.
Thanks Alex the belt’s fine it’s the pulleys on the selector shaft that I’m afterIt sounds as if you need the notoriously brittle drive cones. If so, I hope @Paul Hannaby's suggestion helps.
