G S Haydon
- Joined
- 24 Apr 2013
- Messages
- 1,667
- Reaction score
- 223
Found him!
He also has some nicely done work on the channel.
Still sounds like a right faff. I have a square shooting board, square plane sides and a straight edge, all I need to do is make sure it's sharp, hold the piece on the board, make a few swipes and it is also square. No faffing with the adjuster beyond making sure the blade is square.Not at all, just a little tweak of the lateral adjuster. This is the sort of thing it's for. Also for adjusting if the plane sides aren't square enough for the shooting board.
er.. that's all I'm saying! Faff with the adjuster to make the blade square with the workpiece. That's what it's for........ No faffing with the adjuster beyond making sure the blade is square.
Didn't sound like it. The way you describe it it sounded like constant adjustments to ensure a square result and then some blathering about scallops and scooping. Don't need any of that with a square blade. What I am saying is a single setting of the blade and away you go. It's quite simple if you think about it. Maybe you should give it a go.er.. that's all I'm saying! Faff with the adjuster to make the blade square with the workpiece. That's what it's for.
I love the way forum threads evolve and this discussion is fascinating, but, If I could pull things back a little, I asked for advice in-house as opposed to recommended videos as many here use planes often and I am certain we can sort me out between us. What I need, I imagine, is intermediate sort of knowledge, things like, what is a single iron plane for, is it better or worse than a double iron, when is a wood body better than a metal body, are wood body planes easy to make/restore, what on earth is an infil plane, does the size/shape of the mouth affect anything, how thick a shaving should I see as a maximum? That sort of thing. Really I am interested in what forum members feel is important here
The cap iron allows the iron to enter the cut at its normal pitch, but it creates a barrier.So, how does the double iron work? And, how does the cap iron control tear -out? Literally I found my planes in garage clear outs of deceased relatives. Cleaned them up and they work nicely but I feel like I have little idea of what the bits and pieces do beyond holding the iron in place and adjusting its position
Here are my answers from practical experience. Bear in mind that I'm only moderately good with a plane on my best day All these are what I find, at my skill level.I love the way forum threads evolve and this discussion is fascinating, but, If I could pull things back a little, I asked for advice in-house as opposed to recommended videos as many here use planes often and I am certain we can sort me out between us. What I need, I imagine, is intermediate sort of knowledge, things like, what is a single iron plane for, is it better or worse than a double iron, when is a wood body better than a metal body, are wood body planes easy to make/restore, what on earth is an infil plane, does the size/shape of the mouth affect anything, how thick a shaving should I see as a maximum? That sort of thing. Really I am interested in what forum members feel is important here
Sounds about right!Here are my answers from practical experience. Bear in mind that I'm only moderately good with a plane on my best day All these are what I find, at my skill level.
1. Single iron planes are for rough work, except my bevel up block plane. I get a lot of tearout with a single iron bevel down plane.
2. Cap irons work best for finer stuff, setting the cap pretty close to the edge to reduce tearout. They work for thick shavings if you move the cap back, which I forget and then it's like hitting a wall with the plane!
3. Wooden planes are light and a pleasure to use, but setting them up well is harder. Wood plane bodies distort over time, and wedges wear and warp. If it doesn't all fit properly, the plane doesn't work that well. One day I'll spend time and learn how to fix this.
4. No experience of infills. They fell out of use once the metal double iron plane arrived, which suggests it covered much of what they were good for.
5. A narrow mouth is a way to reduce tearout with a single iron. The double iron can do the same with a wider mouth.
6. Thick shavings are hard work unless I use my wooden plane with a heavily cambered blade (maybe up to 0.5mm shavings). That produces lots of tearout. So I hack it close with that plane, then move to finer shavings. Nothing thicker than a piece of printer paper, usually far less. No doubt better planers than me can take thicker shavings.
But yet you won't find a video somewhere that's any good to compare?Have been at it long time - full time self employed joinery (period replacement, restoration all in old buildings) and occasional bits of furniture. Prior to that in the craft trade and general building trade (well bodging really)
No, only the select few!
Well yes it's not all nonsense. Credit where credit is due!
And vice versa - for instance I do find your Charlesworth planing system somewhat bizarre. Not your fault there's a lot of misinformation about, much along the lines of "reinventing the wheel"!
That's all well and good, I wouldn't want to do this for many reasonsThat was my intention to try to goad professionals into doing their work as normal but setting a camera up. To see what they're doing in a regular project.
I think most people are not comfortable doing that, partially due to the reality that you can be a professional and do exceptional work and maybe some parts of it you're doing in a way that someone will think is stupid.
Try and get into the habit of checking for straight/flat by looking along the thing direct. Hold loose to avoid the deflection you mention. Add winding sticks if you think you need to. They also show any hollow across the width.But yet you won't find a video somewhere that's any good to compare?
I've likely seen near everything what you can see on youtube, and see a lot of bad practice and other strange things.
Charlesworth's principals regarding flat surfaces, and the importance of not blasting off the perimeter seems to go unnoticed, with frequent suggestions of using a scrub plane or rough set jack to plane crossgrain and even beveling the far edge ala Schwarz, I don't care how old or reputable those books are, the demonstration I seen
didn't make sense, as the book was either flawed or misinterpreted, both before and after print. (i.e a planing method for vertical work?)
Try and fight flat like that on the bench and your in for a whole load of effort which won't amount to much.
i.e tediously trying to find high spots on a board, and advancing the cutter until it does
which might not do one any favours.
Things become a bit more interesting when it involves getting rid of deflection,
with many using dogs, holdfasts, does feet and whatnot,
equaling lots of effort, the plane not cutting as it should, and not keeping the same depth of cut, which is important for learning how to smooth without scraping.
And another thing
It took me a while to notice the cleat on he end is far superior than a wide planing stop, which is simply adding more work,
and like the long reach angle poise lamp doesn't seem to be present in many videos.
The easily movable (two finger operation) lamp is very important to me, or should I say for one looking to get the maximum efficiency should they not have a machine for the job.
Not sure if the OP has one, or can get one, but if not able to find one of these
on the bay then there's ones in Ikea for a tenner called "territal" lamps
which are likely somewhat smaller, but maybe not?
Tom
I agree. Most vids seem to be someone's "good idea" of how to do things differently.Should be a video of that somewhere from rough prep to ready, which doesn't have too many bad habits that is a short watch?
