I agree with Paul. However if you really want to measure, why not take a full width shaving and then measure the thickness at the centre of the shaving, and then the edge, a simple calculation will provide the information. :lol:
David C":3cudouxc said:For the squaring of edges I like a camber which relates closely to the thickness of an average business card.
What about thick good quality writing paper as a measuring shim.
Reasonable quality paper is about 0.1mm thick or 4 thou".
David C":uzfc0vyw said:The short answer is yes, though scallops in wide surfaces will be slightly more pronounced than necessary. Some really like this effect.
David C":3q776qhk said:Feeler gauges very good.
Card is easy to find and does not rust or buckle, accurate enough for woodwork if measured with callipers?? ~;-)#
Any slight camber is better than none, don't worry too much about the precise measurements. All that is affected is the shaving width for a particular thickness setting.
David
David C":3q776qhk said:The Odate plates require some Trigonometry to work out the camber on the blade when viewed vertically, because the blade is offered to the stone at the honing angle and the hollow is measured vertically.................clear as mud I expect.
David C":31mhwmeb said:BB,
Don't know much about history (song quote)
Textured, burnt and coloured surfaces seem to be very much the province of the American studio art movement i.e. starting in the sixties and seventies??
Mousey Thompson used adze for tops?
David C":5y5kc4za said:Fraid rather rushed today, cambering a blade from scratch in my system takes no more that 5 - 10 minutes, on an 800g stone.
Describing and showing the process takes nearly 1 1 /2 hours on my DVD.
best wishes,
David Charlesworth
David C":2zejhevn said:Crinkly shaving suggest a chipbreaker front edge problem?
David
