I'm cleaning up an old metalworking lathe for my own use.
It has simple and robust height adjustable feet. Threaded rods with a ball end that sit in turned steel feet.
These were plated - maybe nickel - and as you see are quite pitted.
How would you deal with these ?
I'm not fussy about the appearance but if I just wipe them with grease or whatever they'll be rusting again inside a year and lifting the lathe to clean them is tedious.
Is there an easy way to strip old plating so that I can spray them with primer and enamel ?
Long term is probably to pop them on the lathe and skim them up.
