Hi People
Had a few PM's and questions on the forum re photos , so thought I would do an update
1, When posting photos please only submit 3
2, Please select image size 640 x 480 0.3 MP ( Can be found it menus setup Image quality on your camera ) reason for this is to limit the band width used on the forum and to keep us all on a level playing field re photo quality
3, Please use a neutral background the one I have used is a white cotton bed sheet
4, Fill the frame as much as possible with your entry as that's what the judges want to see not everything around it , If your camera is unable to focus at close distance , move back and use the zoom function and zoom in
Here are 3 example images all taken at 640 x 480 0.3 MP
Colour cast / white balance
These 3 images were taken on auto white balance , as you can see this results in a yellow cast , so you need to chose the corect white balance for the lighting you are using
The above / below / side profile does not need to be precise as if you have a undercut rim it would not be seen from directly above , The 3 shots of your work are to give the Judge the best view of your entry
On my computer , if you hold down the control key and rotate the mouse wheel you can zoom in and out on the image to get CLOSE UP'S :mrgreen:
Just so you are not all quaking in your boots , this is not my entry for this month :mrgreen:
It was my first ever bowl :lol:
