Pete's box
woodbloke
13 Apr 2006
Salisbury, UK
Pete (Newt) asked me to put up a couple of pics of his latest project. Pete's having a bit of 'puter troubles at the mo' but hopefully will be along directly to explain all about it:
Hope you like it...I did, a lot - Rob
Looks really nice, whats the finish, I have just finished a box and was wondering what finish to go with.
Harry
It looks like Pete's unable to get onto the forum at the moment so I'll fill a bit...I'm sure he won't mind. Timber is sapele and lemon wood mitred at the corners and reinforced with lemon wood splines, cut on a jig on Pete's saw. Finish is three coats of oil (if I remember, may be wrong). The feet are not final and simply stuck on with some d/s tape. Pete intends to have a further play around with different feet configurations until a better solution is found - Rob
Folks, Lemonwood and Sapele nice contrast. The top is floating ( small dab of glue in the centre at the ends of the panel) and book matched, the bottom is fixed with lemonwood veneer on plywood. I made jigs for the mitres and splines (see under general woodworking). The mitres are glued with slow setting areldite the splines with wudcare. The finish is 2 coats of danish oil and then a wax (Chestnut wood wax 22 clear). The dimensions are 240 * 140 * 120. The figure on the lemonwood is quite subtle and looks ok against the strong sapele. I noticed that few projects involve lemonwood, it is dense and hard but machines and planes well, there is no need to sand as there is a super mirror finish straight of the plane. Give it a go, it is not cheap, but check carefully for cracks.
sorry for being a little lazy i will search if it was an older post was the jig a recent thing in the general woodworking its something i have to make some time soon thats all :)
i do like the 2 colours go well darker and lighter :)
Lovely box pete - the woods work really well and the contrast in the lid is gorgeous
Rob and I had a play around with a few of Pete's off-cuts of lemon wood. As Pete says, it planes really nice and leaves a smooth, silky finish that needs no sanding. Next time we go to Yandles I intend to get some - as well as cabinet making, I think it will be ideal for making up things like marking gauges.
Cheers :wink:
Paul
Lemonwood is good for longbows. My eldest grandson made one from this wood - lovely straight grained and tough. Being 6 ft 2 in and a competitive teenager, it is not surprising he made it with a pull weight that I can scarcely draw.
I was just thinking that my longbow is lemon wood. Only about 75lb draw weight, unlike some of the beasts in our club.
Our resident bowyer has been seasoning a 4' yew stave since our daughter was born to make a childs bow in a couple of years ;)
