You will find that even the water in a hot water cylinder has to be above a minimum temperature to prevent bugs, look at
https://www.hse.gov.uk/healthservices/legionella.htm
I think I saw an earlier post suggesting a service valve should be added before the unit; not saying this is wrong but just check instructions as some units require a particular length of pipe to allow hot water to expand into.
For a bit of context, I’m not a plumber; I’m a forensic investigator that has somehow specialised in plumbing failures. Very good at pointing out how not to do it but can’t solder for dung!
I suspect that hot water is insisted on, because cold water would be too uncomfortable for people less srcupulous about cleanliness.there is for commercial premises it's for control of legionnaires infection can't quote you all the regs now as they went in the recycling when I retired
Oooooh Matron............A sloppy insert is not effective.
