pompon44
Hi,
This might be well known, but I discovered today that my old Stanley #8's blade is tapered in length... Only slightly (something like 6.5 cm at the tip of the blade and 6.4 cm somewhere around the middle) but it makes me wonder what exactly "square blade" means in that case. It cannot be square to both sides of the blade, is it ?
I assume this has no influence whatsoever as lateral adjuster can correct that, but well, it kind of wasted a bit of my time : I was trying to correct the "squareness" of the cutting edge, and was not carefull enough to check the blade with the square always on the same side... As a consequence, I seemed to go nowhere :-(
Just an observation...
Regards,
Regards,
