Righto I'm about to fit my oak newel posts and handrails using loose oak tenons but I'm unsure which glue to use.
I'll be taking my time cutting the joint so hopefully no gaps, I'm also thinking of cutting the underneath out on the handrails to slide them in from above with the bottom post pulled over a little to allow everything to come together.
Which glue would be best as I'll so be using the odd screw to pull it all tight.
The oak will be finished with Osmo oil just to protect the surface.
