ChrisWiduWood
You might want to sort out that landing skirting as well ... jesus my eyes
That’s being done, the skirting is what was there originally some bodge I have to say. It’s loose, and still in place so I can use it as a rough template for cutting the replacementYou might want to sort out that landing skirting as well ... jesus my eyes![]()
We have moved the whole house more contemporary, all a matter of taste, of which I profess to have zero. I’m working on happy wife happy life.It is a mix of styles, glass infill with wooden rails. The property looks more period, ie last century so I would remove the lot and fit wooden spindles and new post, good opportunity to buy a lathe and take up some turning otherwise plenty of places to buy the parts.
https://stairpartsdirect.co.uk/prod...MI3ICKg6bTggMV8IRQBh0zrA-QEAAYASAAEgIEgPD_BwE
The problem there is that it becomes a full time job, what is in favour this year may well be out next year and you could end up in a state of constant change.I’m working on happy wife happy life.
Isn't that just always the way of things? Plus one for the thin boards glued on by the way.The problem there is that it becomes a full time job, what is in favour this year may well be out next year and you could end up in a state of constant change.
Once the cladding is mitrelocked together they will not move or cup.My only effort was solid with mitrelock...
https://www.woodworkuk.co.uk/forum/viewtopic.php?t=8138Not sure if the pictures are available to others?
Cheers, Andy
That is a nice job, a lot of work but a good result. With hindsight would you have still done it that way or just replaced, I suppose it is a question of your time against cost of premade parts.My only effort was solid with mitrelock...
Oak clad newel stair refit. Picture heavy!! - Woodwork UK Not sure if the pictures are available to others?
Thank you.That is a nice job, a lot of work but a good result. With hindsight would you have still done it that way or just replaced, I suppose it is a question of your time against cost of premade parts.
I have the large one of these Lock Mitre Bits – Infinity Tools and the setting jig, that made the setup so much easier but have never done lenths as long as the ones you have done. What cutters did you use ?
Can i suggest that you plumb the string first as thats how it should have been done.That’s being done, the skirting is what was there originally some bodge I have to say. It’s loose, and still in place so I can use it as a rough template for cutting the replacement
Hi Deema, I’ve got a similar task in front of me, how did yours work out ?The newels look very nice, lovely solution.
