If this is a regular or common occurance then get the condensate pipe altered, either use larger bore once it is outside or get it run internaly to the sink waste.
would that be the case even if the pipe is running internally to the sink waste?The condensate pipe should be around 38mm in diameter and be directed to drain. They are specified to be insulated too but many ‘GasSafe’ installers do not bother. It will have frozen up - you need to identify the pipe as it exits below the boiler and trace its route, then thaw it out. Lagging any visible external condensate pipe should reduce chance of future freezing.
What that is telling you is there is an ignition lockout. There are a number of possible causes including the condensate drain being frozen up and a few other things that I would not tackle on a DIY basis, the clunk is the gas supply valve shutting down. I had my boiler fail at Christmas and found on line manuals which gave very useful fault finding codes from the 3 lights you mention. Could be as simple as the flame sensing thermocouple or the condensate trap being full of scale, be very suspicious of anyone who tells you it's the PCB or other expensive easy to change part without checking. I'm an engineer and used to work for British Gas but not as a boiler fitter, so I still got someone in to fix mine who was gas safe registered and had all the correct kit including CO meter, but found it very useful to be able to talk to him from a position of knowing what the fault might be. Very glad I did, found other faults on my 15 year old boiler, learnt a lot and got a very professional service. With agreement I was able to keep the price down by doing the draining down and simple dismantling myself then ordering parts as required but left the rebuild and commissioning to the person qualified to do it. The first time he rebuilt it there was a minor CO leakage he found with his meter that I would not have know about, turned out to be a slight misalignment of a gasket caused by dirt dropping in on assembly, he said my fault and didn't charge me for the extra time to correct.there are 3 lights on a panel the right one says ON the middle has a big candle flame and the left a little flame with a line. If I try tthe reset button after about 5 mins the 2 outside lights come on and there is a bit of a clunk
I am not a ’Gas Safe’ engineer but would say no.would that be the case even if the pipe is running internally to the sink waste?
Wrote all that waffle then saw you fixed it - sorry should read the whole lot before jumping inMany thanks to one and all for your assistance yesterday. After about 3 hours of pokey sticky with a bottle cleaner etc managed to sort of clear the condensate trap. and pipe. left it overnight and after 3 attempts the thing fired up this morning. So YAY now have some warmth in the flat. @hunter27 mucho grassy ass for the manual as that was a massive help and I actually learned a lot about how the bloody thing works
