Hello,
I have recently started to have issues with blade advancement in my Stanley no.5. When I set the cap iron close to the edge (0.1 - 0.3 mm) I am not able to advance the blade below the sole level. If I move it further away, I can advance the blade more by that distance. For practical purposes my cap iron must be 2-3 mm so that I can advance the blade enough. My original thought was that the blade is too short and the cap iron screw does not allow me to advance it any further. So I bought a new blade for Stanley no.5, which is a lot longer than the old one. But the issue presists.
What I have checked so far:
- I have enough space in front of the blade and below the blade. I have tried to move frog forwards and backwards
- blade is sitting firmly on the frog, there is no debris under the frog, or anywhere else on the plane. I have used compressed air to get rid of any debris
- I tried to align frog straight, so it is not skewed
- when I move the cap iron back like 5 mm from the frog, everything works fine
So the issue must have a relation to the relative position of the cap iron to the cutting edge
Do you have any idea what the issue might be?
Thank you.
Tibor
Thank you.
Tibor
