A
Anonymous
Guest
A couple of extra points on Yew...
it is toxic and frequent exposure to dust (inhaled) can lead to the body becoming sensitised; a definite NO NO for food use...
Avoid heat build up when sanding as this can lead to tiny cracks (aka heat checks) in the surface.
as others have said; beautiful wood to turn (for a softwood!) and wonderful colours and grain are possible.
do take care WiZer, as Mike says, those corners are potential knuckle rippers :!: :!:
You should be able to achieve your aim with well sharpened scrapers (remember, the cutting edge should trail)... this is probably not the best time to learn the hard way about 'catches' with a gouge
Good luck :!: ...keep us informed
