Hi folks,
At last.....the stud walls are up. It took three days to cut, fabricate, and erect the buggers; boy, are they heavy, in spite of splitting the long wall into three parts and the side walls into two.
At the moment, it’s looking rather large, but I know that as the roof goes on it will probably ‘shrink’ a bit. Space is tricky stuff.
Interestingly, the only pozi bit to shatter was the alleged high tech titanium coated one that fitted directly into the impact driver. Fortunately, none of the Toolstation screws have sheared yet, although a small number were bent.The bit to head fit was far better than those from screwfix.
In the pic below, you see my high tech workstation, that is to say my thirty year old Delta sliding compound saw and equally old B & D Workmate. I don’t think that they owe me anything after all that time....boy have they had some use. And the saw is still in excellent condition. Mind you it has spent its life indoors...err, the dining room was my workshop. :shock: :shock:
Today we cut the first roof section. How the hell we will lift it is yet to be worked out.
Firstly, the pattern was drawn on the concrete floor in woodworker’s pencil, it looked enormous. Then with good old Sketchup, the cut angles were worked out, and the length of each chord measured. We did a few trial cuts of the angles to see if they fitted the lines, and whether the saw markings were reasonably accurate, as we don’t have an angle checker. I had some doubts about being able to set the angles repeatedly, but it seems to work.
Fortunately, every piece of the roof has a twenty degree angle, so we will cut each length of timber in half at that angle, and then do all the apex angles and then the feet.
You may have noticed that the timber looks rather wet, I think, having come direct from the treatment tank....great. This is the reason that we haven't fitted the binder yet, as that load was saturated. So much for the treatment only penetrating approx. 6mm. Fingers crossed for sun, sun and more sun. Or at the very least, no rain :roll:
That's all for now folks....Dick.
