rafezetter
Troll Hunter
no point leaving this here - I was merely trying to offer another alternative.
Level off the damaged area if required and cover the whole lot with another sheet of stainless steel, maybe including folded returns to also cover the wood edging? Slainte.Does anyone have any ideas about the best way forward?!
You need someone with one of these.Well, it's a new year and I have probably just made my biggest DIY disaster to date!
Last year I posted about making an island unit with a stainless steel top Stainless steel for island.
Yesterday I was doing the final touches routing the oak lipping so it was flush with edge of the stainless steel. All was going well and was doing the final edge when I caught the corner and the router kicked up across the top causing:
Now, a huge part of me is just very happy and relived that it was the stainless steel and not any of my fleshy parts that got caught. My better half doesn't quite see it like that at the moment.
Scrapping the top and starting again is not going to happen so I have to try and minimise the impact. Does anyone have any ideas about the best way forward?! I have seen kits like repair kit, perhaps used in combination with steel putty. Or, if anyone knows of a company that might be able to fix dings like this and they are in the Edinburgh/Fife/Dundee area then please let me know! The last thing I want to do is take abrasives to the area and make a big patch that doesn't match the rest of the top. Perhaps we just live with the scar - at least we won't have to worry about making the first mark in the top.........
(edited to try and get images to show)View attachment 101340View attachment 101341
I've already said all of that Julian and I'm in complete agreement with you. The OP has accepted it an come up with a solution, but as is often the way of this forum, it falls on deaf ears of others who have to show how high they can water or wave the tackle around.
I'm not a professional welder, in fact I never finished my grading, instead deciding to finish uni and make less money. I can use TIG to an acceptable level as I can with MIG, Arc and gas (or at least I could, haven't done a whole lot in recent years and the muscle memory has gone). I stand by my original comments, no way, no chance, not a hope. all this carp about pulse welding it doesn't make a jot, it will burn, it will warp and it will not finish nicely, to get a weld it has to get hot full stop end off. it's so thin that it will not sit back, so you'll either be on a hiding to nothing trying to shrink it (remember that father ted episode with the dent in the car?) or you'll have a bulge.
not mention finishing it. I'm not about to let someone start grinding and linishing in my fresh new kitchen.
but hey, good to see I was right on the last page, it's at a page and half more discussion after the OP has made his mind up and I'm sure it will continue a pace for the next few days. starting to see why folks fecked off.
A good TIG welder could fill the worst of those dings. When I used to weld sheet goods like 316 we only peeled the protective film back a couple of inches each side and the heat is so localised it does not melt the film. TIG is unlike any other type of welding and is often referred to as the Rolls Royce of welding techniques. So long as you do not penetrate right through the glue will melt and then reset.There is no way you can repair that with weld. Not a chance. Zero possibility. Don't even bother.
Sorry to see this has happened to you. If its not repairable could you maybe make a butchers block or similar to cover that area, sorry doesn't solve the issue but just an ideaWell, it's a new year and I have probably just made my biggest DIY disaster to date!
