I didn't think to look. The brick system is called Best Lock not Lego although Lego compatible.Real Lego?
Ah found it - I think that's bloody great!! Very nice! You absolutely should be proud of it too!Not in the league of the fine achievements I see every time I visit this thread but nevertheless I finally got around to making the 1st of 2 or 3 cd storage units. All because I have them on a shelf in my small workshop along with 100,s of vinyl albums and singles taking up valuable space .It was a case of using what I had so not perfect . I did however enjoy the whole process from design to construction so here it is …
I made a few mistakes I’m sure you will spot but overall I’m pleased with it.
A tip for coat racks is to hide the fixing screws under the hooks.Sometimes I end up making things that I don't consider to be overly exciting but needs to be done...
Coatrack for the utility room
Then I needed to move the clamps from the wall as I needed the wall space for something else, plus there wasn't room for the other clamps I want to get so I decided to make a mobile clamp stand, it's not the best looking bit of woodworking in the world but it works and it only sits in the workshop...
Thanks - i, m planning a 2nd but unfortunately a recent worn out clutch has left me £700 lighter so it will likely be a little later this year . lots of examples of the members work here and like I said it’s from an across the board of skills and abilities.Ah found it - I think that's bloody great!! Very nice! You absolutely should be proud of it too!
Nice work, I bought a bunch of those covid systainers as well, some of my original ones are getting knackered and I need to get organized. I like your rack design, its nicer than the normal plywood slabs.I’m in the process of swapping vans & as it’s a completely different make I need to make new racking, I’d seen a thread about cheap medical systainers & found someone local selling them for £10 each which I figured was a bargain & ideal to base the new racking around.
The systainers are quite tall so I decided to make ply boxes to fit inside so I could easier access the gear at the bottom of the box, a mate cnc’d me the base of the boxes from a program someone posted on hear, after that it was just a case of cutting the sides to size & running some grooves in the bases.
I made 12 two for each systainer simply glued & pinned together
They fit nice & snuggly, I’ve added a simple dowel handle to lift the top box out.
The systainers are going to sit above the rear wheel arches so I made a start on a unit to hold them.
I’m trying to keep the weight down as much as possible so it’s made from 60x24mm redwood & ply, this is as far as I’ve got up to present
There’s more to do to get it finished but I think this will work well & eventually hold 4 systainers
Not quite a Grinling Gibbons but my first attempt at carving …
Now I be hoping I can do as well with me own first reliefer.
It sounds like you are some way ahead of me - other than a bit of chip carving this is my first go. I’m hoping that as my experience builds getting a smooth(er) finish straight off the tool will happen!Now I be hoping I can do as well with me own first reliefer.
Will you go further with yours, perhaps with the scrapers and sanders? I like the idea of finished-from-the-gouge-or-knife but, in the spoon & bowl making, I've yet to find such a finish good enough as my techniques with gouge and knife are still in need of improvement. But its also a matter of taste. In fact, some of the bowl carvers seem to make a very smooth from-the-gouge finish then have-at it with a gouge to put 150 gouge scallops in it as decoration.
I'd be interested in your thoughts on what degree of finishing is .... appropriate; best for certain purposes; etc.?
Robert mouseman thompson embraced the textures created by the tools, tool marks are part of hand made and make pieces individual
There's some Mouseman copies in our house, made by one of his apprentices in the same way as the Mouseman made them. All the surfaces are thicknessed and finished with a long handled adze swung between the legs as the worker stands over or on the part being adzed. The adze blade has a very shallow sweep so the surfaces look flat until you see them in a raking light or have a feel at them. A skilled adzer can make very regular scallops that overlap but in a very uniform fashion.
These surfaces look and feel very "real" in a way that flat surfaces don't. Flat is rather unusual in nature; the adzed surfaces are like the surface of a lake that's rippled by the wind.
I'd like to make bowls with a similar but scaled-down surface, given a final wall thickness by using regular in-outs of a shallow-sweep gouge. Here's a rather good vid from Strongway tools in Ukraine that ends up with such a finish.
