blackadder2
New member
Could somebody tell me the name of this type of fastener and possibly where i may obtain one.
They are used to join the legs of a pine table to the the top.
It consists of a solid steel cylinder 12mm in diameter and 30mm long with a slotted top and a hole drilled into the side to accommodate a m8 stud .
This slides down into the top of the leg and the stud is inserted into the side of the leg at the top and screwed into the cylinder.
a nut is screwed onto the stud which attaches each leg to the corners of the table top through a steel corner plate.
It is a common commercial way of fixing but i don't know what they are called
