I'm not 100% clear on the law here, but it certainly feels illegal to mention a clamp wigwam without providing a pictureEven my clamps now have their own portable wigwam
Sean
even the beer fridge is on castors
Beautiful countryside out there I'm in Pembrokeshire buddy so only a stone throw from rosslare
Beautiful countryside over there. We vacationed in Pendine a few years ago. If I had to live somewhere else, it would be Tenby or Manobrier or somewhere like that.
Sorry, off topic!
https://www.axminstertools.com/bosc...utm_content=1792&tagrid=49436877&glCountry=GB
This one mate ? Sounds fantastic. I did have a look at it . Does it have a depth stop ?
Thanks Martin, what's the flip saw like ? I was looking at them but was worried they might be a bit of a gimmick, bit of a jack of all trades ??
Sorry for the late reply, yes that is indeed the one. It does have a depth stop feature, and I have used it for lap joints myself, and can attest that it has almost no "flex" in that either; of the several other mitre saws I've used, when using the depth feature, (a turn screw to set the blade height against a metal plate), that usually said metal plate the screw rests on is not rigid enough and therefore flexes when pushing down for the cut, thus cutting a shade too deep without extreme care being taken and giving sloppy lap joint results. The Bosch however doesn't suffer from this.
If you do buy it I would also recommend you pick up a digital box angle finder, one of those magnetic small things to attach to a blade or base or whatever to "tweak" the 90 and 45 deg stops from the factory (a screw with a locking nut) as mine at least was off. Mine is the "GemRed" version I've had it for years, and has been very useful for all sorts of jobs when even a small torpedo level is just too big, or it absolutely has to be X degrees - invaluable for table saw blade setup.
The process is easy to tweak the bosch and I can walk you through it if you need advise.
Let me snap one over the weekendI'm not 100% clear on the law here, but it certainly feels illegal to mention a clamp wigwam without providing a picture
Sean
