roombacurious":3c3cmm1r said:
Two other questions on the subject of motors:
1) How do induction motors compare to brush motors with regards to torque and speed (rpm)? Is a 1,500w induction motor more powerful than a 1,500w brush one and why? Which on will be rotating faster (at shaft level, without load and gearbox)?
2) Why are pulley systems used in pillar drills to change speeds, rather than simple electronic variable speed controllers (like in hand-held drills)? It doesn't seem logical (or cheaper) unless you want to keep the motor running at the same speed all the time to take advantage of the maximum torque obtained at a certain speed of rotation.
More food for thought...
A universal brush motor will, in theory run infinitely fast with no load. It will in practise run at 20-30 Thousand rpm and at this speed destroy itself by flying apart.
NEVER ever try out one of these motors without a load. Typically they will designed to run at 10-15 kRPM and hence need gearing down for nearly every purpose. They are suitably cheap, nasty and noisy for short term use such as hand held drills.
Motors salvaged from modern washing machines are mainly of this type and have sophisticated electronic feedback controllers dedicated to washing machines. Unless you really know what you are doing, these are only suitable for what they were designed for.
Single phase induction motors only run at one speed which is (120 x mains frequency / number of poles) minus a little bit.
eg 2 pole 2850 rpm , 4pole 1425 rpm, 6 pole 960 rpm.
Single phase induction motors cannot be run at other speeds.
Three phase induction motors also run at speeds defined by the above formula but can also be run from an inverter which generates 3 phase power at variable frequency. You cannot run a single phase motor from one of these inverters as single phase motors require special starting arrangements that 3 phase ones do not.
This is a complex subject and I hope I have helped answer without creating too many more questions but feel free to ask anyway.
Bob
