woodbrains
Jacob":3u4gvt93 said:Why? What's the difference?woodbrains":3u4gvt93 said:....
However, there is a subtle but important difference between carving tools and plane irons/bench chisels. Carving chisels are double beveled, to some extent, so stropping of both meeting planes takes place: a regular strop on the bevel and a slip strop on the inside bevel. This will not work on planes unless you want a back bevel and is to be avoided at all costs on chisels. ..
Hello.
If you actually read the above, it explains that it would introduce a back bevel to the blade. You know full well why a back bevel on a bench chisel is not a good thing. On planes it might be useful, but only if you intend it, otherwise it will just make sharpening unlikely to produce the sharp edge you expect.
Mike.
