woodbloke
Mr T":15jg65lh said:Hi
To get back to the clamping problem. I use mitres quite a bit in carcase furniture, reinforcing them with biscuits or dominoes, so I need a positive way of clamping them up. I use shaped clamping jigs clamped to the pieces then an F or G clamp across the corner as shown here clamping up a frame.
This is one way of cramping mitred frames and as others have said, however big the job, you need two pairs of matched pieces, notwithstanding the different jointing methods used at the corners...but Chris, what happened to the cramping block inside the frame? - Rob
