mitered corners
T.allan
31 Jan 2008
Co Durham
I've tried the table saw, the miter saw and that miter saw that wobbles in the frame it came in and the results are reasonable. However I seem to get better results using the plastic box with the mitered angles already cut.
Is it good practice to turn the wood over for each cut or change the position of the saw each time I make a cut?
If you are expecting perfection straight off the saw, then you should cut the left and right-hand ones by changing the position of the saw rather than by turning the workpiece over, because you are likely to get saw tear-out on the underside. This is particularly the case with pre-finished products like picture-framing.
However, I think you will get the best results with a mitre shooting board. That way you get clean joints on the top and the bottom, too.
You can find my design for one in British Woodworking Issue 12. See [email protected] if you don't have it.
Steve
Edit - Ah, Paul beat me to it :)
On my box making I finally settled for the tablesaw, made a jig, and to do the other end I can turn timber around instead of over,
I use a 60T blade and two clamps on the jig and another clamp when I am setting constant lengths. 99% success my way.
You can see my jig in boxmaking wips.
I'm very impressed with the above information. I was beginning to blame the tools for the chipped ends of the wood and it is a simple problem to solve. The shooting board is brilliant and I did watched the video. Steve You solved the chip problem and the other suggestions have also totally solved my imperfections. A great big thank you to you all.
