Thanks, I try to share as much as I can, sometimes though I think people will be bored watching me make something.Amazing skill and very interesting to see how you have solved problems along the way. It is beautiful!
I never get bored watching things like this, I love mechanical things. You can see how they work and what's going on as the parts move round. I enjoy hearing your thought process as you build the model.I think people will be bored watching me make something.
Never! Keep up the good work.Thanks, I try to share as much as I can, sometimes though I think people will be bored watching me make something.
For the insulation I think it's a balance between theoretical and practical application in such a miniature environment, and also conduction vs radiation.
- A trapped layer of gas would in theory be effective but you would need a decent gap 10mm+ to prevent radiant heat becoming dominant.
- Glass fibre etc has great performance in theory but once you compress it the performance drops, so how you would maintain effective performance at low thickness would be difficult.
- PIR or foam type insulation is super effective but getting a good uniform layer would be tough, perhaps spray foam a layer then turn off the excess to get a consistent 3-4mm thickness, then wrap in something for structural protection. Zero experience if this is possible.
- Neoprene could be a good balance of performance and practicality to apply and structural strength.
Brainstorm, perhaps helpful perhaps not.
Fitz.
Hi Gordon, thanks, hadn't seen that. I have just tested some ceramic matting that I had already, but will get some of this too to test. Best regards, NigelNigel - there are specific insulation materials for model boilers - it normally takes the form of ceramic matting, which is quite flexible and easily cut to size - Page 10 of this catalogue is just one example.
G.
