Have you ever heard of a captain's table? No, neither had I.
This is the underside, but it is an oval coffee table sized table where all 4 sides fold up into a tray so it can be quickly carried away. Note on the right hand side, I believe at some point the side was turned over, as there are those two small brass hinge supports (which became a small issue later). The only examples of this sort of table I could see online were for sale for around £2,000.
So a client wanted a base made for it, but crucially it could not be fixed to the table as the whole point is that it can be lifted away, so with nothing to refer to and no previous examples to look at, away we go!
I had recently bought some lengths of recycled oak skirting board/architrave, which I felt would be perfect for the rail, so I cut to length, sanded and (after this photo, obviously) mitred. Because of the tables framing, I had to cut dados at each end and in the middle of the side pieces, and very small dados in one of the end pieces to accommodate the brass hinge supports as well.
Once this was all done it was almost possible to pick up the table top by the rail alone, as the fit was nice and tight.
The legs were from another piece of oak I had to hand, this is at dry fit stage. The two legs that were at the hinge support end had to have a small piece taken away to allow for the hinge support to go fractionally beneath them.
I decided that I didn't want any screws etc, so used 4 dowels per leg to fix them to the frame.
Staining came next, and i got really close to the original colour with a blend of these two stains, as individually none of my stains (I have quite a few) were close enough. It was important to the client, and to me, that the frame looked the same age as the table top so once applied, I wiped off as much stain as possible to give a aged patina look to it all. I'm very happy with the final result of the staining.
So here it is, almost finished. Feet to be added, a bit of buffing of the legs (and dusting of the table top) and finally, 50 years after my client's mum bought the table top at auction, it becomes a very interesting and useable coffee table.
