Rhyolith
Is there any particular benefit to verticals? or is it just personal preference?
Rhyolith":636l38cw said:Is there any particular benefit to verticals? or is it just personal preference?
Rhyolith":260dzavc said:Found a couple on eBay that seem quite small:
https://www.ebay.co.uk/itm/Milling-Mach ... 1438.l2649
https://www.ebay.co.uk/itm/Centec-2-hor ... 1438.l2649
Either of these the sort of thing I should be looking for?
There are two types of nipples I have found on the machine so far:Cheshirechappie":3m9nmij5 said:Grease nipples - actually, they're probably not grease nipples, but oil nipples. Exactly the same principle, but use an oil gun with something like a medium viscosity straight lubricating oil (don't use engine oil, it has a high proportion of detergents and other additives that work very well in a high-temperature high-speed environment, but not so well in a low-temperature low-speed one).
You can get special way oils for machine tools, designed for use in high-pressure very low-speed places like the traverses of milling machines. Especially worth it on the vertical traverse (knee to column) because it'll stay put and not run off into the chip tray.
Have had a quick look on eBay, your right the machine vices are expensive! Looks like £100 budget is required to get anything decent. The table on the Milnes is 30x8" (bit over 8", see pic), I am assuming the spacing of the slots is standard, it came with plenty of bolts for the slots.Cheshirechappie":3m9nmij5 said:Keep your eyes peeled for a good milling vice. Won't be cheap, but don't be tempted by anything small and weedy. Half the secret of good results with a milling machine is a really rigid job-holding (and tool-holding) set-up
Having watched quite a few machine repair/renovation videos on youtube, a common theme is that the lubrication systems don't work, or don't work completely.Rhyolith":1qb974q7 said:Its 1940s - 50s and apparently a high grade machine http://www.lathes.co.uk/milnesmiller/ (thanks DTR for finding that)
