SLM
Oops! Sorry Tom, I quoted the wrong response … it was someone else wanting to do stainless screws.
Even if you put a barrier between the screw head and the steel, the actual threads of the screw would still be in tight contact. I don't see what you could do to prevent it.
That's true. I like your answer.No they wouldn’t. The further apart the materials are in the galvanic series, the more readily they will form a corrosion cell. Brass is actually fairly close to mild steel, and so as long as there is no electrolyte (eg salt water), there’s unlikely to be a problem with those.
