Finished up this, turns out it wasn't a regular thread afterall, even though anM6 nut could thread onto the old grub screw, not so the case the other way round,so went ahead and drilled it for
an M8 tap, which made that decision up for me, and having the three good taps and drill was nice.
Not knowing if the gib actually was still in the block, I took a chance as it felt good and full adjustment was available.
Probably should have taken the pinion and handle assembly off again to check,
but still had the other half of the gib material after cutting it.
Crossed me fingers and hoped for the best.
Missing few photos of the more "interesting stuff", sorry about that,
best the camera isn't too close if the going gets tough.
Pretty sure the hole wasn't actually on centre, so things look as they should.
Can just about make out the fit of the gib, with the more feint line on the right side.
Close enough to keep that gib centred...wherever it is....
Thankfully there was the casting there which would keep the gib from sliding
I reckoned it was worth having a go, and thankfully things went smoothly and successfully,
no hint of any discrepancies whatsoever.
Found a nice wee hex bolt, but maybe better off finding something a bit longer for grinding a point later on, as its hard to know how well it is holding the gib, I reckon it's likely plenty deep into it.
Cleaned up and done some plunge testing, the fit is exactly as I want now as it loosened up the tiniest bit
Still way too stiff, but somewhat tolerable for the jobs I use this drill for.
After which the tramming test with an L shaped rod was done, and thankfully the quill still plum, a also checked again with the quill lowered...
another substantial phew, as its now bolted to stay at 90 degrees!
Had another test with the long bit, and still seem to have some movement, thankfully much less,
and quite a lot more force required compared, but it still ain't no Bridgeport.
Now I've got the quill more stable with the gib,
New v belt, some decent hold downs made,
An indexing jig for centering the work
(possible table support)
Hopefully it will be the last of my cattywompus holes.
Still could likely start putting some money into this for a dial indicator and base,
to at least try and make those MT's a bit nicer, or spring for a new chuck...
Hopefully I can get away without that stuff.
Besides there maybe more lessons or experiments to be learned, possibly for drilling an
oversized'ole which needs be done.
That will be interesting, keen to get testing my jig again and rig up for drilling again.
Likely confusing photo underneath as the jig's getting table height set before changing bits and after which centering up on the smaller bit with what could potentially be a lathe vice
I'll likely cross that bridge only if I need to.
Eager to see how things go.
Tom
