• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Micro Lathe
DavidConnelly
28 Sep 2021
Edinburgh
My friends dad passed away recently and had a selection of tools to pass on. I've been asked to sell this beautiful wee Selecta micro lathe, which appears to be in working order. There are various other components with it. I've looked on ebay etc and they vary greatly in price.
I'm looking for 2 things.
A sale
A fair price.
Any advice gratefully received
    1.4 MB
    3.8 MB
    2.2 MB
    4.2 MB
    4.3 MB
    4.7 MB
    4.5 MB
They do vary greatly in price - that one seems to be in good condition and is with the original box - I'd guess £300 to £400. Suggest you also check and maybe advertise on the model engineer forums.
G.
The box is a bit fragile but it would be easily packed. I suppose it would depend on how much it cost. But yes I think sending it would be ok.
£250
Buyer pays postage.
Its approx 13kg
44cm x 24cm x 14cm
Itll be slightly heavier and larger when wrapped in packaging
Nice little machines, price depends on condition and what extra bits come with it. Yours doesnt appear to have the drilling adapter pillar or centres and a chuck. May also be missing the headstock lever, a splined shaft with a long thin lever with a black ball end, this is usually used in conjunction with the drilling pillar, and I suspect came with it as a lot which converts it into a pillar drill. Still perfectly usable as it is and I would have thought £250 is about right. With the extra bits above then you are talking £400+. I bought mine a few weeks ago and have just finished a few mods, and started actually making stuff with it. Pretty accurate, but you have to take it gently as they can only manage very small cuts, particularly with the standard motor which is a tad underpowered. They will run up to 6000 rpm though, good for very small stuff in alloy or brass.
Jewellry-making daughter in the US has that machine, but with the milling/drilling attachment. Absolutely perfect for her use, as while its capacity is limited, it's incredibly versatile. One thing to watch; the older ones have a different nose thread from recent models, and accessories are a bit more difficult to source.
I won't say how much this cheapskate paid for it!
For anyone who has one of these I was recommended a seller on e bay, ralfrubine, German site that carries all sorts of stuff for the Unimat range. RDG also do a very nice independent 4 jaw chuck for the 12x1 nose for £50. There are more accessories for these than you can shake a stick at, power feeds, screw cutting gear, a circular saw, fret saw, milling heads and tables. The list goes on and on. Get bitten by this little machine and you could spend a lot of money! I intend to use mine just for making some small parts for watches and clocks, very convenient and the high speed is handy. Have changed the motor on mine for a 200W with variable speed. You can buy these ready made to fit but they charge over £200 for the conversion kit. If you have some very basic fabrication and turning knowledge then you can buy the bits necessary for about £70 and have a fun morning doing it yourself. Other than that I found the spindle bearings on mine felt a bit gritty. Easy to strip down and I just cleaned and repacked them and it now runs very smoothly. Another tip I was given by a long term owner of one of these is to take off the handwheels and make sure there are thin shim washers fitted between the back of each wheel and the casting it bears on, makes them much smoother in operation.
