Benchwayze
monkeybiter":3bpdz1oo said:I'd get a big sheet of thin steel [side of a freezer etc.?] and fold the edges up without cutting at the corners in case you decide to use coolant at any point. If you think that's a possibility you could even cut a hole and solder in a threaded boss with a plug screwed in, then you can retro fit a sump & pump when wanted.
Thanks Mike! I never fort of dat!
Now I can make that 'Barbiekue'. :mrgreen:
