I have a problem with my workshop build. I purchased a continuous dry verge system (which is basically a long peice of pvc plastic with an 's' shaped profile, that clips over the tops of the roof tiles so you don't need to mortar the edges afterwards. Problem is, it was supposed to be installed before the roofing battens as they hold it tightly in place. I didn't know this and have already laid all the tiles so now can't install the continuous verge in a satisfactory way. Obviously I didn't install a cement fibre board either, so I don't have anything to hold mortar in place, so now I don't know how to finish the gable ends.
Any advice? I know you can buy a continuous dry verge system that fits AFTER the tiles are installed, but it's £100 and I could do without that.
Would installing the upvc fascias butted up against the underside of the slate tiles work?
