lurker
Le dullard de la commune
I have a really nice weller soldering iron station for the usual soldering tasks, but I now want to have a go at lead soldering stained glass.
Any suggestions?
Any suggestions?
morturn":3mozdbr4 said:The ideal soldering iron for stained glass is a temperature controlled electric iron of around 100 watts.
So if your weller iron is that power, it will do the job.
AES":3u03ejod said:Those old fashioned irons are, IMO, still the best for such work - you file up the tip to whatever size/shape you want (they're solid copper on a steel shaft with a wooden file-type handle), put them over the gas stove on the special holder until the flame turns green, tin the tip and off you go, perfect results every time. And because you have 2 irons, as soon as the 1st one gets a bit too cool, you swap it for the 2nd (which was of course, already warming over the stove).
Caveat - I've never done any stained glass/lead work, but as you can shape the tip as you wish, I GUESS it would be a great tool for that.
bugbear":14t8mt8c said:AES":14t8mt8c said:Those old fashioned irons are, IMO, still the best for such work - you file up the tip to whatever size/shape you want (they're solid copper on a steel shaft with a wooden file-type handle), put them over the gas stove on the special holder until the flame turns green, tin the tip and off you go, perfect results every time. And because you have 2 irons, as soon as the 1st one gets a bit too cool, you swap it for the 2nd (which was of course, already warming over the stove).
I've seen quite a lot of stained glass workers on TV; they all seem to use a large electric iron. I don't recall seeing a "lump on a stick" type iron being used.
(and a quick google around the net for people selling stained glass (AKA professionals) showed electric irons were universal)
BugBear
Rorschach":2k4zbmf3 said:If you are doing it day in day out then I am sure a proper electric iron is perfect. However it is also probably expensive. A second hand old style soldering iron costs probably a few quid at your local car boot.
bugbear":3q2vzyze said:Rorschach":3q2vzyze said:If you are doing it day in day out then I am sure a proper electric iron is perfect. However it is also probably expensive. A second hand old style soldering iron costs probably a few quid at your local car boot.
A quick search showed RS (not known for low prices) selling a 200W iron with a 3 year warranty for £45.
Given the cost of coloured glass and lead cane, I'd say the iron is the cheap part of the craft.
BugBear
