• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Makita plunge saw, full kit, £351 (110 volt)
I bought a 110v sander by accident, I didn't read the details carefully. I decided to buy a transformer - £55 at the time - rather than send the sander back, it worked out at about the same price the 230v sander woud have been. A couple of months afterwards I bought a huge Hitachi mitre saw cheap because it was 110v - I didn't realise it had a transformer with it - and festool jigsaw cheap because it was 110v. 110v extension leads come up regularly on FB MP, Gumtree and at car boots, I have too many, and I cut one up to hard wire fixed outlets in my workshop and my garage - I don't move the transformers.
Many knowledgeable people reckon 110v stuff is more reliable than 230v.
This offer is at B&Q, NOTE 110 VOLT.
Saw, case, two 1.5m tracks, bag, joining strips, clamps, £351. Delivery only.
The 240 volt version of this kit is about £500.
I would buy it if it were 240 volt
https://www.diy.com/departments/makita-sp6000j-kit-110v-plunge-saw-165mm-blade/0088381639002_BQ.prd
I have re-checked this advert and am not convinced it comes with guide rails, and if so what length. If anyone is thinking of buying then a bit of caution would be sensible.
If you look further down in the Product Details it says "Guide Rails Available Separately"
Specifications of the SP6000J Plunge Saw Max Cut @ 90 : 55mm Max Cut @ 45 : 39mm Blade Diameter: 165mm Bore Diameter: 20mm Input wattage: 1,300 No Load Speed: 2,000-5,200 Net Weight: 4.2kg Total Shipping Weight: 20kg SP6000J1 Plunge saw is supplied with: B-09298 SPECIALIZED Plunge cut blade hard MAKPAC Carry Case Guide Rails Available Separately
I think someone has made a bit of a mistake with the advert and if ordered you will only get the saw and MAKPAC case, the advert also states the cable length is 100m.............
I think you are correct, hence my warning above to check the advert. When I originally posted this it appeared to be a very good buy which I thought someone may be interested in.
