OwenRS
Yeah I'd also say a Negative hook angle blade is a must for a Mitre, Snip or Cross cut machine. Finish will be perfect and they never snatch.
Take a look at the 254mm 60 tooth CMT Blade Ref, 294.060.10M
Or the Trend 254mm 60 tooth Ref, CSB/CC25460T
Both are great little blades that have a 30mm standard bore. Reducing rings to most sizes are only a few pounds to buy. The reducing ring only centralises the blade while you clamp it in place with the flanges so don't worry about them.
