Sgian Dubh
Help yourself to it, although bear in mind the dimensions I used are random. I just used numbers that seemed about right for the height and depth of a coffee table like structure. I could send you the .dwg file, but if you don't have access to AutoCAD I suspect it's not much use to you, and I could also supply you with the PDF 'printout', but that's set to print at A4 so you'd need to muck about with magnification and possibly multiple sheets to get the printed dimensions to match the actual dimensions.sunnybob":2hvnaykf said:Is that drawing available for me to copy and expand? It would certainly save me many hours marking out.
Alternatively, take the information in the JPEG of the CAD drawing in my earlier post and replicate it as accurately as you can on a piece of board material, ideally something like 12 mm MDF which is easy to work on its edges, shape this by any means you can and use it as a template for use with a router and top or bottom bearing pattern bit.
Jacob is right that in your case it looks like you'll have to resort to that old standby of paper and pencil - not unless you know someone with a CNC machine that could run my CAD drawing for you. Slainte.
