Making a door
hi i have just had to replace a pane of glass today in a door with the same curve on top. the bottom and two sides were beads the top one was one solid piece moulded with the top of the door.
Just made this out of American White Oak
Following the top rail being set out it was cut out on the bandsaw
Then sanded smooth on a sanding block on the spindle
Following this a small rebate block was placed in the spindle with a bearing collar added to the top, the bearing collar being accurately turned on an engineering lathe to give an half inch rebate (i.e. 1" smaller than the rebate block
the moulding on the opposite side was applied with a bearing router
the beads were laminated by using the spindle as a thicknessing sander
then laminated between two pieces of mdf
once glued the thicknessing sander was used to clean up and simension to size
and subsequently moulded with the router
ready for fitting
If you need more info re the actual making of the door let me know
(thanks to motownmartin for showing me how to place images in posts)
As shown with he rebate block and the turned bearing collar, it works like an extremely large bearing router cutter but the bearing needs to be exactly 1" smaller than the rebate block to cut an 1/2" rebate
looks great. is this a process you use alot making doors?
one thing that i have been wondering for a while now, is the gun stock stiles your door has, how did you cut them exactly?
Great to see another Craftsman added to the forum ! That is class work !
