Just made this out of American White Oak
Following the top rail being set out it was cut out on the bandsaw
Then sanded smooth on a sanding block on the spindle
Following this a small rebate block was placed in the spindle with a bearing collar added to the top, the bearing collar being accurately turned on an engineering lathe to give an half inch rebate (i.e. 1" smaller than the rebate block
the moulding on the opposite side was applied with a bearing router
the beads were laminated by using the spindle as a thicknessing sander
then laminated between two pieces of mdf
once glued the thicknessing sander was used to clean up and simension to size
and subsequently moulded with the router
ready for fitting
If you need more info re the actual making of the door let me know
(thanks to motownmartin for showing me how to place images in posts)
