Jacob
What goes around comes around.
New house means new shelves!
What's a good mains detector and how reliable are they?
That is why some are much more expensive like the fluke, it is not expensive if you are working in customers property and could end up not only repairing the cable but also to re decorate a room.with the silver foil on one side as that renders these devices pretty much useless, I've found.
Thanks for that. £90 is good value even of if it only saves just one or two hits.I assume you mean something to find cables in walls before you drill through them. The first is any cables should run vertical from a socket BUT having seen them laid diagonally and in many other odd configurations then a decent detector is worth having but they do not come cheap. Using a cheaper tester will give an idea but with less certaintity which is less of an issue in your own property providing there is RCD protection.
The one to look at is the Bosch, available in screwfix Bosch Truvo Digital Detector - Screwfix
There is a more expensive version that will detect much deeper but I doubt you are using 4 inch screws.
The Bosch one is available on Amazon at a better price
https://www.amazon.co.uk/Bosch-detector-one-button-handling-Detection/dp/B01J1FN7ZE?th=1
They also do the more advanced version at £90 but I doubt you need all those features, by the way the professional Fluke detectors are around £700 !
If in any doubt then before drilling turn of the local sockets after using the detector just in case someone has done some dodgy work and the cable for some reason has no electrical protection.
When the Bosch ones came out a lot of us electricians moaned because they "didn't work". The hand trick was in the instructions, if I remember correctly!The detector will settle down and work properly. It applies to volt sticks and to the Bosch type detectors both.
That is not quite right - cables can be vertically or horizontally in line with fixtures as well as in the corner and top of wall zones as already mentioned (they are now called prescribed zones).… The first is any cables should run vertical from a socket…
… devices like the Bosch that work but with much lower levels of certainty…
Were you using the device on cables that were dead ? The advantage of the Fluke is that it does work on dead circuits by injecting a signal which allows you to trace particular cable runs.is there a live cable here?
No, live. It seems to thing EVERYTHING is live though. It’s just massively over sensitive for live electricity, and it also is wildly inconsistent on finding studs.Were you using the device on cables that were dead ? The advantage of the Fluke is that it does work on dead circuits by injecting a signal which allows you to trace particular cable runs.
With this I was able to inject a signal at the consumer unit and trace the incoming mains service 100 metres up and down the street under the pavement before I lost signal ....If you want a decent detector that also has signal injection then this is what you want
https://www.test-meter.co.uk/fluke-2042-cable-locator
