Made a Planter Box
Cordy
1 Dec 2014
Wigan
Started with a pile of 6 x 1 par and 4 x 2 scant; all cheap Redwood from Wigan Timber
Sadly, the Bosch crosscut doesn't have an indent at 30 degrees :(
So used the Incra on my D/W contractor saw
Yes, I lowered the blade before actually cutting :)
These 18 parts cut on Cross-cut
This old dust-bin is a perfect fit when perched on those paving slabs
Made good use of the Pocket/hole jig :)
31 inches high, which is quite tall for a small garden
Folks comment that it looks like a Pulpit
Here is a bi-product, I cut the 4 by 2s the wrong way :oops:
So made this
...the toy props bought on eBay, all plants from B & Q Wigan
rest I did myself; paint is acrylic
LOL glad I'm not the only one then :)
You might want to add some finish to the underside of the top, as rain will still run under there (no drip edge) and rot it out - you should also consider adding some rubber "door stop" feet to it to keep it off the ground.
Otherwise, perfect use of a dustbin :wink: One of my planters is built around an old central heating expansion tank.
Cheers Rafezetter I will try to fix a drip to top, then look to keep base off ground
John, what is the finish on your pulpit please? I need summat equally bright for acres of verandah woodwork.
Sammy Q, I will check what type of Sikkens later
Sammy
Top coat -- Sikkens Cetol Filter 7 plus
Base -- Cetol HLS Plus
Both are shade mahogany; originally bought to treat Sapele
My choice was based on these excellent threads
Roger M 1
Roger M 2
Cheers. Mine are presently dull ancient oak stain, more like muddy chocolate; new stuff sometime soon and I want to have a brighter finish.
Sam
